T25/T28 on a B18?
Szady
D-Series Master
Is a T25 too small for a B18a/b motor? Going to swap in a B18a, and I want to turbo it and swap it all at once. I cant seem to find any turbo manfolds for B series motors with a T25/T28 flange on it. Any insight?
TiiM iiS l3eAsT
Scamming Piece Of s**t
t25 is going to max out at around 220whp.....i think its to small in my opinion....
silentdaredevil
Its not slow, its lag
depends on how much boost you are running. If you running a low 8-10 lbs you'll be fine. But you have to keep in mind that this turbo is going spool super fast. Probably around 2-2500k, which means when your just cruising along (assuming this is a daily driver) you will be in boost all the time. It can get annoying. Just my 2cents
Szady
D-Series Master
Im gonna be on stock internals, shooting for 250whp, which is doable. I already have the T25 turbo, so thats why I wanted to go with it. Its gonna be at 7 or so psi, b/c of the internal wastegate on the turbo. Anyone know where I can find a t25 manfold for a B18?
toneekay
Rubbin on yo booty
Local or other forums? Possibly ebay?
silentdaredevil
if you can't find a manifold have someone make you an adapter plate.
guwakjai010
Dr Tai tai
ebay makes t3 to t25/t28 adapters... BUT i wouldn't go wit a t25/t28... atleast go t3 but in my z6 i had a t3 .48 AR it was quick but i hunger for more POWAAA lol so t3t4 for then next turbo is sc61
umair
you wont make power past 5500-6000 RPM but your power goal is doable. i would try to get a big 16g or an evo 3 16g if i was you. those turbos are underrated.
TiiM iiS l3eAsT
agreed ^^^
Szady
D-Series Master
What other turbo's have T3 style flanges? Ive come across other turbo's (tdo4h, tdo4e, ect), but I have no idea if they'll fit on a T3 flanged manifold. If they do, I'll just get the t3 manifold, and one of the tdo turbo's.
Szady
D-Series Master
I found a tdo5 manifold. Will a t25 turbo fit on it? The flanges look the same, I just dont know if theyre actually the same size. Any ideas?
