there's a clip that holds it in from behind
under the arm part of the crank there will be a little notch in the plastic
stick a flat tip screw driver in there and try to work the clip off
once it's off the crank will slide right off
it's hard to explain, but REALLY easy to do
someone with pics would do you more help
