Tapping Dome light
bman11
just wondering what the easiest way to tap into the dome lgiht would be? im putting leds in my foot wells, so im gunna tap the cct right there, just dont know what the easiest way would be. Is there like a simple tap or something i can just connect through the wire?
bman11
also, the manual says my circuit for the interior lights is under the hood, how would i tape that circuit in the under hood fuse box?
honda98civic
leds are gay. but its ur car so do what u want. but why would u tap into the dome light? just runia wire from ur battery to a switch and then to the leds. then run a ground from the switch to a metal bolt somewhere. so u can turn them on with a flip of a switch
bman11
ya but i want them to come on when the doors r open to
honda98civic
oooook. lol
u can buy these wire tap things. it has 2 slots to put wires in then u push a pin thing and it cuts through the insulation and touches bare wire. thats the easiest way, but have fun running wires through ur headliner.
eskateboarding7
The dome light is a negative trigger if I remember correctly. Sometimes you can grab it in the driver A pillar, but not always the case. Use a DMM and you should eventually have no problem finding it.
