tapping for oil return and feed line
Gonzo
Tin Foil Member
basicly where ever. As long as its above the oil line also make sure you dont have problems with the line hitting the dp and make sure you can still get to your oil pan bolts
majorahole
get a stealthmode oil line kit. it will tap into where your stock oil press. sensor is. and when you install the drain you will want it to be above the oil line in your oil pan. about 1-1.5 inches down should be good.
Steven.
Formally Green 91
