TD05HRA-16G on a D16
chunky
'94 hatch Si
can i use this turbo on my Z6? it's a stock evo8 turbo. me and my friends have been arguing because it's a twin scroll and nobody knows for sure. and if so what would i need to do?
Steven.
Formally Green 91
i dont see why not? whats the specs
its a 16g, i belive people run 16gs all the time
chunky
'94 hatch Si
i don't think the problem was with the size, but more so because it's twin scroll. 1 person said i would have to make a custom manifold for it. anyone know if this it true?
Steven.
Formally Green 91
with the 2 openings, i dont think you HAVE to, but it woudl surely help.
Q. What are twin scroll or divided inlet turbine housings? What are the benefits of using a twin scroll turbo?
A. A "twin scroll" or "divided inlet" means that there are two separate volutes within the turbine housing. The main reason for doing this is to isolate the pulses coming from each exhaust port and maintain more of the pulse energy from each cylinder all the way down to the turbine wheel. There are no differences between the turbine wheels used in open or single inlet turbines compared to those used in twin or divided inlet turbines.
Generally speaking, a divided inlet turbine setup will respond faster and produce boost quicker than single or open design of the same nozzle area, of course this is dependent upon proper execution. The simple fact that a divided housing is used does not guarantee these results.
While it does not cause any problems or harm to run a divided inlet turbine housing on a manifold that is an "open" design, none of the benefits of the twin inlet will be seen.
chunky
'94 hatch Si
so a normal manifold will work, it doesn't need to be divided? could i just use a HF mani with an adapter plate
Steven.
Formally Green 91
i woudl step up the manifold to a real log manifold, just becouse your using that turbo
ryan89crx
Spoolin single cam!
likely there are no adapter plates for that snail.
most people that sell flanges for it sell ones that are divided. you would need a custom manifold to fit the flange
chunky
'94 hatch Si
it's for sale/trade in the parts section now, i'm just going to use a T25 or T3
