Dimorphic
I recently noticed whenever I start the engine and when I rev then I noticed that temperature gauge goes down and back up after releasing the gas pedal. So when the engine is cool, it is ideally dropped to the bottom, when I rev it would even go lower then when you release the gas pedal, it would go back to the the starting temperature.
As the temperature rises, I keep on revving then it would also simultaneously go down a little every time I step on the gas pedal and when I release the gas pedal it would rise back up again. But when the temperature is stabilized (just below half of the gauge, the normal temperature) it seems pretty normal when I rev.
What at are your thoughts in this issue?
Thanks!
Note: This is in neutral and idle mode on a flat road.
Thanks!
