after 4 months of experimentation, i have found the only stuff that will lube your window rails. liquid wrench/silicone grease. I have used white lithium, wd40, pbblaster, wheel bearing grease, chassis grease, high temp moly grease ect ect.
Everything dryed out within 1-2 weeks, and actually jammed my windows. I had to soak the window rails in wd40, and take a q-tip to get as much off as posible.
I then got silicone grease from home depot for 3 bucks, and this stuff has worked well.
