tired of messin around im goin type R
TurboTravo
ok first off ive decided i wanna go N/A and i know my lil d wont be what im lookin for. Its gonna take me a while to save up but i want either the B16B or B18C5? what are the advantages and disadvantages of each compared to each other? and can u do alot of mods to these motors if any? thx
munky
I would go GSR, instead of ITR or CTR, personally.. get the B18C. That motor is a great motor, and that's the motor you see the best gains out of. plus the itr is friggin' expensive
B16B (CTR):
1595cc (DOHC VTEC)
Horsepower: 185hp@8200rpm
Torque: 118lbs-ft@7500rpm
Compression: 10.8:1
Bore: 81mm
Stroke: 77.4mm
OBD: 2
Redline: 9000rpm
B18C (ITR):
1797cc (DOHC VTEC)
Horsepower: 210hp@8100rpm
Torque: 134lbs-ft@7500rpm
Compression: 11.0:1
Bore: 81mm
Stroke: 87.2mm
OBD: 2
Redline: 8900rpm
B18C (GSR):
1797cc (DOHC VTEC)
Horsepower: 178hp@7600rpm
Torque: 129lbs-ft@6200rpm
Compression: 10.6:1
Bore: 81mm
Stroke: 87.2mm
OBD: 2
Redline: 8200rpm
Si_Racer13
JDMchris>>>
id get the ITR over the CTR motor anyday. Why? because they cost virtually the same, but the B18 has the bigger displacement along with the extra torque that the B16b lacks.
TurboTravo
well i wanna get a type r cuz everyone has a gsr motor or b16. i wanna be diff
child_racer
Jspek kid
there are tons of mods for each....(it can get costly though) but IMO its surely worth the cash spent. A built type R motor OWNZ N/A
edhgreatone
don't get the b16b because you'll never have any torque go with the 18's
green
You Can DO IT!!!
munky said:
B18C (ITR):
1797cc (DOHC VTEC)
Compression: 11.0:1
Bore: 81mm
Stroke: 87.2mm
OBD: 2
Redline: 8900rpm
is the itr 210hp? I thought it was at 200? wow...
munky
the usdm one has 200, but the jdm one has 210. the jdm motors tend to have about 10hp more than the usdm ones... at least from what i've seen
TurboTravo
and what are some sites that have mods for the itr? im tryin to do as much research as possible
Zak8022
mods will be relatively the same as any B18. the only problem you might run into is if you get a JDM b18c (ITR) cuz it may have some wiring issues. im kinda guessin, since a friend of mine has a euro accord type r engine and had a few more differences than your normal H22. just a word of caution.. try findin someone who's swapped a jdm itr if you decide to do that. its been done, so they will be able to help you alot and give a heads up on things you would run into.
RICDOGG
it's because they have higher OCTANE gas over there.
97civicracer
itr....higher compression....bigger displacement(more torque)....just as high revs.....and type R transmissions have shorter gearing...better for 1/4 mile times which i assume is your goal....i wouldn't suggest driving it too much on the highway...not much for top-end....when i say not much i mean alot...just not quite as much as the gsr...but who wants to go 150mph anyway.....
