and add a dremmel bit set to that as well, it does every job possible.dremmel man, dremmel does everything
a sawsall does everything.. it saws all
yah but if the dood is asking people what tool he should use , im thinkin he might not be qualified as a sawsall operator, stick with the drimmel less likely to lose a hand or doorNot if you know how to properly hold and operate a sawsall. A dremel will be much easier to get in such a tight spot but either one will look just fine if done right.
