Trick for exhaust gasket?
joei24
Hello
I have a 98 civic lx. It has the 3 way converter which I
Am changing. It came with this ring like gasket that I think
Goes in between the cat and the first pipe.
The problem is that I can't see where the ring fits.
The bottom of the cat is flat and the ring is too big
To fit in the groove of the pipe.
Is that gasket supposed to be ring shaped?
No gasket came off when I took the cat off
Thanks
Joe
JohnS.
BANGARANG
Are you referring to something like this?:
The wider end is supposed to go on the end of the header with the narrower end pointed into the cat.
JohnS.
BANGARANG
I think that one should go after the cat, to the mid-pipe.
