Trouble shooting
Mr.Baker
Mr. Search
One of two obvious things, battery is on it's way out or alternator is not charging.
Get a meter to check the voltage.
connies96hatchie
Reinvent Your Shell!
After you've done Mr. Bakers suggestion, a few other possibles could be...
-Take both positive and negative terminals off the battery for 15 minutes. Put them back on and see if it clears.
-Sometimes even corrosion around the terminals can throw the sensor off. Can be cleaned up with baking soda and water.
-check ground wires.
-Can also take the battery out of the harness to check to see if any debre or wiring is crimped around the housing.
If car runs - take it to Advance auto and let them test it out.
If car does not run, take the battery to advance and they will test it. Bad battery - replace. Good battery - check alternator.
