True or False
ST8JDM
i heard that you can lower the compr. jst by geting a thicker head gasked is this truE or False ??
d16z6
hardcore97
Hard Core
its true but its not the best way to lower it
jason_guy_yeah
yeah, it's true but if your boosting, you'll more in likely get a blown head gasket. Well...depends
ryan89crx
Spoolin single cam!
Cometic makes some thick gaskets :thumbs up
add some ARP headstuds and you shouldnt have a problem
Shiznit
Stickin it to the Man
youll only blow the headgasket if your head lifts under boost. headstuds will prevent it from lifting
ST8JDM
thnks for all the info so this is not a very good way to lower the compr. am only shooting for 180-190whp so am not planing on building internals
bcivichb
Driving South
im pretty sure it doesnt make a big difference anyway
hardcore97
Hard Core
thats what i was thinking, wouldnt it have to be really thick to make much of a difference?
hybrdthry911
i concur, for the d series cometic thick HG and def get some arp head studs.
Shiznit
yeah it does make a big difference, compression is compression. it doesnt matter if you used pistons to lower it or got a thicker headgasket.
Stinky
East_Coast_Chopstix
will lower compression significantly drop low-end power... Im gearing my setup mainly for auto-x, and need the low, mid-range power to get the car out of the corners...
I spool at 200rpm now, but lower compression might make me spool later ??
ryan89crx
Spoolin single cam!
keep it in a lower gear. most of the auto-x events ive seen the motors are running pretty high revs throughout the whole course.
if you are spooling at 2k, i dont see why you would be out of boost much during the whole thing
ryan89crx
Spoolin single cam!
Stinky said:
well... it spools at 2k right now, but will it still after lower compression.
Our local events are a Super tight track... and speeds top out at 35-40mph (you'll never see 3rd gear, first just spins out, and second is at low rpm coming out of a tight turn.)
one of my runs from last season:
http://smg.photobucket.com/albums/v502/jaredkay/Jareds Civic/autcross/?action=view&current=9_24_06_autox7.flv
you shouldnt notice much spool difference even with lower compression
ST8JDM
So this HG is not such a bad idea IF i get new head studs any good places to get the HG and The Studs
9.12-8.5 Sounds preaty good to me
plz keep in maind that this is a low budget Turbo!!!!!
ST8JDM
LongGrain said:
if your really on a budget, you can just double stack your head gasket
Ok is not that bad, am all in for good parts i jst dont want to drop 800$ on internals on a D am building this to see how i like turbo and if i enjoy it GSR-T here i come !!!!!! and then i'll be more than happy to spend all that $$$
i really dont expect the motor to last more than 6-8months not that i drive hard but am planing on pushing 10psi on a 135xxxd16z6 its getting a really good tune i'll be pushing the D to the max STOCK
get my idea lol
