Ok so I am going to probably buy that book that was mentioned in the thread before about Turbo set-ups.
I am going to go on a limb however and assume that it probably doesn't go into detail about the pros/cons of a B18 vs. a B16. In the 4G section there is a comparison about running an LS B18 vs JDM B16 with V-TEC. I've always heard that a non-vtec motor is seemingly easier to tune than a vtec one because of a few problems that I am not going to even try to mention due to my ignorance. However in the case I want to run a mild turbo set-up on my 6G, would B16 run better because of it's design or the B18? Granted you can pick up an LS motor way cheaper than B16 but is the extra money worth it, and then also what about the V-TEC issue....is it really harder to tune?
