turbo d ?s
offroadin88
looking to boost a 96ex stock d16y8. Ive looked around and I think building a kit from scratch will save me the most cash. Just figd before I start buyn parts I should make sure I have a good list. The engine is a 80k stock motor. Let me know if I left anything out or sudg for diff parts. thanks
Turbo manifold
Turbo t3t4 .57 trim
38mm 7psi wastegate external
greddy type s bov
jdm 2.5 intercooler piping kit comes with the bov and wastegate couplers clamps etc for 220 after shippn
Intercooler from ebay?
walbro fuel pump 255lp
Dsm 450cc injectors
DSM Resistor box
Boost oil temp air fuel gauges
oil lines/ vac lines
k&n cone filter
spark plugs stock or...
msd coil cap 6a box?
so theres the list will i need to do anything to my comp chips etc. I know one oil line runs from the turbo to the oil pan via a bung in oil pan, wheres the other oil line come from. what other stuff have I left out... to make good reliable power... Im poor so parts will be bought over the next 2 months as money comes in anything I can buy first and install now to boost up a few ponys that work now and will work with the turbo set up.
thanks guys I may be a dumb noob but ive tried to do my searchin just want to make sure i dont f up and burn up my daily driver
Shiznit
Stickin it to the Man
4 things.
1st) youll need some sort of fuel management. i recommend an obd1 chipped ecu. and for you to run that youll also need to get an obd2a > obd1 conversion harness. youll need this for the reliable power youre talking about
2nd) youll need a downpipe
3rd) the oil comes from the back of your block, or you can get an sandwich adapter plate that screws into where your oil filter is. i prefer the sandwich plate cuz then it will be filtered oil going to your turbo.
4th) dont install anything until you get EVERYTHING
tuning is key for reliable power
