turbo help!
93civeeDX
so i traded my rotas for a half turbo kit.
i got a manifold, turbo, downpipe intercooler and all the piping.
i need a BOV injectors, and a chipped ECU.
butt i was told i can use my apexi VAFC with 440cc injectors and do something with the fuel??
but im not too sure about that. it s a D16Z6 with lotss of miles. but idc if she pops, cause i got a new DOHC ZC fo FREEE! and im gunna swap it in and i just wanna boost this z6 till it pops.
i need injectors if anyones got some!
i need a chiped ECU i have a P28, so mabey someones got one and we could trade with cash??
im just tryin to peice it to gether asap! its all for fun. build it break it build it stronger next time.
opinions? advice? help?
s_crowley 17
my advice is to not break your motor, whats the fun in that? Just tune it to around pounds and youll be making somewhere near 200ish horsepower..
My opinion is that it could possibly be an ebay turbo, have you checked for shaft play?
You also should upgrade your exhaust to atleast 2.5 inches, way better flow that wont restrict anything
Esotericimage
Taking an H-T break
hows your clutch? hope you have a good radiator in it. wasegate? theres alot that goes in it. and you will break and replace s**t that WILL break. Its not just a plug and play thing.
If you look on some classifieds, im sure you can find what your looking for.
www.go-autoworks.com and www.Xenocron.com has EVERYTHING your looking for.
xxsenceo89x
aka superman
Just get the oil lines and a tune. Dont even bother with that VAFC s**t unless youre a cheap f**k. Those cant adjust the timing only the fuel but use the stock ecu(if youre obd2. If youre on a buget dont buy anything that you dont need. Clutch should be fine till about 160WTQ. Stock radiator/exhaust is fine.
Shoot for a whp. Dont go by psi. It means nothing. Its all about how much flows through.
D-series.org
Kensai
What kind of turbo is it? What kind of BOV?
Faisalicious
why do u wana blow that D16Z6 :( ?? thats one of the best D series engines ever built. I have one with 327000 km or 196200 miles on it, and im almost done with building the bottom end, its not that expensive...
93civeeDX
it has 234xxx milies on it. and i got a DOHC ZC im gunna swap in it.
and im gunna build that for boost wile its out. but i was told even if i boost the z6 to 8psi it should last for a good amount of time no matter what. im notlooking to dump money into an engine that doesnt have much of a life left in it.
Kensai
Ok. 8psi coming a GT35 turbo is different then if its coming from a DSM turbo...
