turbo help
19dmann90
I have a ls bottom end that has shotpeend rods and stock pistons i want to vtec and boost it i have both gsr and b16a head what would be better for boost? this car will be my dd so i only wanna push 8psi what size turbo is recommended?
2fast.
psi doesnt matter. how much hp are you lookin for?
Autoworks
ON the heads...pick one, from what it sounds like on your build, it wouldn't make a difference.
2fast. is correct, PSI alone means nothing. Get a power goal in mind.
techavluis
i think i would go with gsr head. but its very true about hp goal first. (thats where ive want wrong a few times)
Jersey8
B20: Detroit Muscle!
b16 head has lower compression, but the gsr has quench pads that reduce risk of detonation
if your going to be getting a good tune, which you should be anyways, i would go with the b16 head
civhatch92
That's my honda.
B16 for lower compression.. then just get an excellent tune and your good to go.
bizak
Who said psi doesn't matter? Psi does matter, you can't be like I want 300 hp but i want to run 5 psi.
Next time own or build a turbo car before you put ur 2 cents in. In my opinion, either head will be fine, if is your dd car and you are not going to upgrade ur internals I would suggest don't push no more then 10 psi and with a good tune you can be running 220hp+
