Turbo Kit 90% done
quikshift
HIT IT WITH A STUPID STIK
I've gotten just about all the
-pipes
-injectors
-fuel pump
-HKS SSBOV
-manifold
-vafc
-turbo timer,
now i need the 2 important things, a turbo, and an intercooler
what type turbo could i get if my goals are about 14's in the quarter mile? I have a d16y8
help me out
SeanMc300
professional a*****e
boost controller? lines? then you need your downpipe made after you get your turbo.
depends on your other mods, tires, skill
TurboZinc
Good luck hitting 14's. There was a 99 or 2000 SI at the track not too long ago with a T3/T4 hybrid only running low 15's, high 14's.
iamgod
AHAHHAHAHAHAH thats f**king weak, that guy must have not been boosting much or something was wrong with his engine or driving
SeanMc300
yeah, boosted sohc's can hit low 14s easy. that guy must of sucked d**k
AZSprmnn
From AK to AZ to AK to OR
yeah i know i have a friend with a GSR N/A and hes runnin or he claims to be running mid 14's
quikshift
i forgot to add the downpipe in there, I have an intake and exhaust right now, i wanted to go for a swap but i thought that turbo would be a better bang for my buck.
my tires are ok but i need better ones, maybe some proxies, and i'd say i'm ok with drag, not the best but ok
I want to run about 5-7 pounds of boost with the car
SeanMc300
what size turbo, pipes, exhaust, injectors?
quikshift
I need helping picking a turbo out, 2.5 inch pipes, around 2-3in exhaust pipes with 440cc injectors
I want to make the civic be a daily driver, but also quick
SeanMc300
you could also get a t25, the 14b is slightly, very very very slighty larger. with a t25 (which is what im going to be using) you can see a full 8psi at about...3000 rpms.
as far as exhaust piping, you should use 3 inch if you can, i have a 2.5 inch exhaust already...so im sticking with that. but go for 3 if you can.
2.25 is a good size, 2.5 might be a little big for charge pipes.
if you got the vafc hack, and have someone who is knowledgable tune it, you could see about 220hp...so about 175ish whp. thats good for 14's.
here is a site for basic tuning the vafc hack http://www.thedropshop.tv/vafc.htm
Sound Streamin'
Boost or Die
Please tell me you got all the necessary guages? If you don't, then you arn't near being done. You need a boost gauge, air/fuel mixture gauge(a good one not a cheapo), fuel pressure guage, and an ouil temperature gauge. You'll also need a breather(not a big deal cause they cost like 5 bucks.) Don't forget a boost controller.
quikshift
I've got most of the guages except for the fuel pressure, thank you guys for all the help
quikshift
I forgot to put that my manifold fits T3 and T3/T4 or Hybrid , IHI
Ravage70
t3 48/60 is the best size for a d
gives u the most power at the higher rpms and conserves ur 30mpg at cruising speeds
t25 will be boosting and wasting ur gas when u dont want it to and this is true with similar size turbos like the rhb5 and 14b
boosted_si
Depends on your manifold...What flange does it have on it?
FYI...My Si hit 13.9 on 6.5lbs of boost...running waaaayyyyyy rich on crappy tires...
14's shouldn't be very hard...SOHC's are pretty decent motors
