Turbo Oil Lines & Water Pipes
scooby_killer
Hi Lads Ive Got My Civic Which Is A 1995 Vei (d15z1) Engine I Am In The Middle Off Doing A Turbo Conversion To It But Am Stuck Ive Put My Exhaust Manifold And Turbo On But Dont Know Where The Oil (in) And Return Pipe Attach To On The Engine Also Where The Do I Connet My Water Pipe To On The Engine If Any 1 Could Please Help Me That Would Be Great Pictures Would Be Even Better As I Can See What Goes Where Thanks Lads.;)
TiiM iiS l3eAsT
Scamming Piece Of s**t
post some pics of what you have done.....the oil feed(which goes from the oil pressure sending unit to your turbo) should be facing upward........the oil return(which goes from turbo to oilpan) is usually the bigger hole.....the oil return should also be facing down .....the water lines im not sure on really.....do a search on turbod16.com......im sure you will find more info on there....
scooby_killer
ive had a look on there and did some seraches but cant seem to find any thing can some 1 help please thanks.
scooby_killer
thankyou CHAOS i now know where to get my water feed from but can some one tell me where do i ge my oil feed from ive been told you have to Tee off at the pressure sensor at the back off the block dose any 1 have a pic of this or knows where the pressure sensor is thanks.
95_civic_lx
get a tuner toys block fitting....it only fits in one place....;) (thats where the oil sending unit is...big green thing next to the filter
