no 5 psi untuned will kill your engine. It will create a lean condition. the stock honda ECU can only compensate fro about 1psi of positive pressure(honda defines it as ram air) after that your causing damage. If he has enough control to stay out of boost he will be fine, but who has that much control?Blahman240 said:Major wrong information in this topic! If you don't run alot of boost till you're tuned, you'll be fine. Like 4 or 5 psi.
or directly blown itio_303 said:I would not drive it untuned at all. Untuned + boost = detonation
youll have to be very very careful. despite what anyone tells you, the more air you force into your car the more fuel youll need to keep it from detonating. even if youre running 3psi, you still need more fuel PERIOD! i strongly recommend you dont try driving you car without tuning it after you install a turbo.ken2830 said:Is it atleast possible to drive it under no boost to a place to tune it?? Or drive around just till i get the money to tune??
i too..Shiznit said:youll have to be very very careful. despite what anyone tells you, the more air you force into your car the more fuel youll need to keep it from detonating. even if youre running 3psi, you still need more fuel PERIOD! i strongly recommend you dont try driving you car without tuning it after you install a turbo.
