its a 2006 rsx-s wtih a greddy kit on it. Its tuned at 9psi. Its got a greddy profec B boost controler. On low its 9psi and on high its set to 14psi. When i set it to high and go WOT the power feels weaker then the 9psi one. anyone know why?
could be that the a/f mixture is not up to par with the amount of boost is producing, or you have a leak somewhere, i would take it to a reputable tuner before something really bad happens
thats what i thought. But shouldnt the computer know that there is a incorrect a/f mixture and add more fuel because there is 750cc injectors so its not like that would be a problem.
hey computer will know but is its not tuned to run a 14 ps1 its not going to do it you have to tune it to run the high boost then when you put the boost lower the comeputer will add less fuel the compuet can not add more then what it knows only less
