Turbo Setup question
Jdm_civic_ek2
URBAN DISTURBANCE CC
Hey guys im looking into buying a kit off my buddy, it comes with the turbo, mainfoild, gauges, intercooler, timer, greddy b.o.v and wastegate. My question is i have a complete stock motor (d16y8) and i want to know what all i need to get this kit working and on my car?
bmoua
First of all you should maintence your Y8 before you throw the turbo on. Depending on what you did and didn't already yet you'll need to replace timingbelt/tensioner, colder spark plugs, and anything else motor related that needs maintence work. Also get a compression test...make sure your motor is in good shape to run the turbo or you'll have problems down the line.
what kind of turbo is it? It looks like your getting a almost complete setup. From what you stated you'll need to run a oil line to the oil pan, piping, other gauges if your missing them, aftermarket injectors, ecu (i recommend CROME only) and a aftermarket fuel pump. Upgrading to a stage 1 or 2 act/exedy clutch would be alot better. AFter the install get a good tune and you should be good to go.
Jersey8
B20: Detroit Muscle!
just curious, why do you recommend crome only?
lkailburn
i'd recommend crome as well. cheap(base is free), effective and a world better than an fmu or hack hahahah
-Luke
Jersey8
the only reason i ask is because i want to go turbo in the spring (gotta save that $$$) and i know everything i need/want for my setup except for tuning. i want a approx. 200hp 8psi daily driver, but i dont know what to use for tuning. i was thinking aem plug and play but its o so expensive. what would you guys recommend? crome? hondata? anything else?
