turbo setup
Rocko790165
Next summer Im hoping I will have my B18b1 swap turboed. Here is what my setup will be.
B18b1 with B16 pistons
B16 tranny
Exedy stage 2 clutch
ITR flywheel
CTR N1 pulley
ARP head bolts and main studs
CT26 turbo
turbo manifold
external wastegate
XS manual boost controller
FMIC
Ebay piping
1g DSM BOV
1g DSM injectors with resistor box
Golden Eagle oil lines
Tuned with either chrome or uberdata
What I was wondering is with 10 pounds of boost do u think I can reach 250whp and still have it be a reliable DD. Thanx.
jason_guy_yeah
:cussing: PSI?, I know it can handle 300whp daily. Depending on the tuner, elevation, humidity,... and the qurks of the engine. The psi is???
ryan89crx
Spoolin single cam!
why swap out the pistons? stock block will work just fine...
ryan89crx
Spoolin single cam!
Chaos said:
agreed^^^
ur block will be fine for around 250 hp....
stock block LS have made nearly 400...
you can run 300 easy as a DD if you have a good tune
Destroy
Its not even this summer yet...
Rocko790165
The block came with those pistons in it thats why im using them, and how much turbo lag do you think I will have with this turbo also how long would it take to reach full boost if set at 10 PSI.
