Turbo setup
Boostin
To start off i have a 1993 civic coupe. Im pulling the engine tomorrow. Heres the list of parts, please tell me if im forgetting something and opinions appreciated, Thank you.
Full rebuild kit- Gaskets, oil/water pump, timing belt, pistons, and bearings.
Turbo kit- ram horn manifold, .63 oil catch tank, intercooler.... theres the link vvv
http://www.ebay.com/itm/D15-D16-D-SERIES-RAM-HORN-MANIFOLD-T3-T4-63-TURBO-CHARGER-KIT-INTERCOOLER-11PCS-/170751731735?hash=item27c198a817&item=170751731735&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr#ht_3095wt_1185
AUS 750cc injectors
255lph pump
Neptune and demon tuning kit- LINK vvv
http://www.hamotorsports.com/demon-neptune-package.html
SPEC stage 3 clutch
*Im also sending the block and head to the machine shop and once everythings together im taking it to the exhaust shop for 3" straight from down pipe.
Tell me if im forgetting anything ? i was thinking about head or main studs ?
Thanks again
2slo4u
wait4me
Well for starters I'd invest in a better turbo kit. The manifold will crack at the welds. Kits that come that complete for that price are usually... .....nvm..are garbage.
Your planning on tuning it yourself?
DarkCreep
D16Y8+T
Get one with a log manifold. Those ramhorns are garbage and will crack at any chance they get.
Boostin
Ok, maybe ill just go with a cast iron manifold for now? and i was going to try, but if its to complicated ill bring it to a dyno shop
2slo4u
wait4me
do you have any experience in messing with timing and air fuel management or know what numbers are good and bad?
obracer12
also, what kind of life does your motor have left?
did it pass the tests? (leak and compression)
miles?
along with the other guys questions
Boostin
Honestly no but im learning alot online by researching and figuring out how the Neptune system works. and it did pass all the tests
