Turbo timer recommendation
killaruna
I'm currently using this el-cheapo turbo timer, the background LED is kinda f**ked up and reading is not very accurate. so i'm gonna whip up a couple of bucks to get myself a new turbo timer. anybody got any recommendation. prefer something that has cool design, lighting and good functions. i'm currently eyeing on this Greddy Full Auto Timer. any opinions on it? =)
B16A2_CIVIC
Think. Feel. Drvie.
i like the greddy turbo timer so get it lol
killaruna
Features
* Bright, illuminated display
* Two standard programmable countdown presets (P-1, P-2)
* Two auto timer modes (A-L, A-H)
* Stopwatch / lap time and attack modes
* Built-in voltmeter
* Built-in speedometer
* Small, compact design
less than 100 bucks for this timer.
B16A2_CIVIC
Think. Feel. Drvie.
i think its good cuz i was planning on getting it when i go turbo
killaruna
well generally the function of a turbo timer is to cool the engine down. so i guess no harm in getting one for NA cars. =)
B16A2_CIVIC
Think. Feel. Drvie.
nah a turbo timer is to keep the turbo cool and filled with cool oil not to keep the engine cool if u dont cool down the turbo its called coking will start and mess up the ball bearings in the turbo so thats wat it is for go to www.greddy.com
B16A2_CIVIC
Think. Feel. Drvie.
ok ima type this down from a book i have....
Adding a turbo timer, is a good idea to help prolong turbo life. The timer allows the engine to continue to run, even after the ignition is turned off, so that oil can flow through the turbo and cool it. If hot oil is left in the turbo housing it can solidify (called "coking"), which will leave deposits on the turbo bearings. - Super Street 2005 Buyer's Guide
i got that from that mag
Revolver
Oct 10th
There is no use for an N/A car to have a turbo timer if it has a good cooling system, oil and water.
The reason a turbo car needs a turbo timer is to let the turbo slow down after a hard drive. A turbo is spinning at 100k+ rpms and to turn the car off while its still turning that fast is like draining your oil out of your engine while its reving at 8000rpm. Also, a turbo is a huge heat sink. Letting it sit at idle isn't gonna cool it down by any more than 20 degrees or so. A water cooled turbo and or a very good oil cooler are the only things that will make a beneficial difference to cool down your oil when at idle, not a turbo timer.
killaruna
ahh alright, well now i understand. so usually whats the recommended time for a turbo timer? i previously set mine to about 20 sec.
iamcivic
zdnfhsz fhz
LOL, 20sec? for turboed cars its 3-5 min.
Revolver
Oct 10th
My old Saab had a water cooled turbo so I only needed to let it sit for 2 minutes at most. I pretty much let it idle and waited for the fans to kick on then shut down the car when they kicked off. I didn't need a turbo timer.
civic!
my daughter is the s**t.
ANY car N/A or turbo will benefit from leting it run for a minute before you shut it down. especially after spirited driving. it gives the cooling system a chance to catch up. if you want to kill your car quick then do just that... drive real fast then pull into a parking lot and just shut it off. it won't last 100,000 miles like that.
lkailburn
don't get a greddy. i personally have one and its flaky as hell. and have talked to others with the same problem.. it works "sometimes"
