turbo timer?
SiRcivic27
that harness is so that you dont have to cut into the factory wiring for the ignition, it basically makes the install plug and play under that part of the dash. I just installed my Greddy Turbo timer and really like it. If you went to go greddy you would need to run wires to the ECU for VSS and to the e-brake to the e-brake sensor.
your HKS link is really GREDDY.
stealthy
4 Doors For More Whores
thanks, i fixed it. but with the cheap ebay one its just two wires?for the greddy one with that harness would i still need to run wires to the ecu for vss and to the ebrake/sensor?
Steven.
Formally Green 91
i wouldent go to cheap with it.
you dont want it to fail and not work at all, or leave your car running lol.
HKS ones ore nice, i have one but i avent used it yet
ryanM
thats what i was thinking, come back an hour later and your car is still running :rolf:
stealthy
haha true, good point
SiRcivic27
it should be that way with all turbo timers, the VSS tells the TT what RPM and speed you're going to calc the run time, and the ebrake sensor lets the TT that the ebrake is pulled and okay to let the car run when turned off. It took me some time to get used to my TT, I need to pull the ebrake and have both my feet of the pedals for a couple seconds then turn my car off, otherwise it wont let the car run when I turn the key off.
Destroy
Are you in the market for one? Be aware that there has been fake apex i's on ebay. Ive always recommend Blitz.
ryan89crx
Spoolin single cam!
why even run a turbo timer? how often are you running your car hard and then immediately shutting it off?
just drive easy the last mile of wherever you go, and you will be fine
stealthy
i just ordered a Greddy turbo timer and a harness for my car....my buddy has one on his STI i like it, so that was my deciding factor on what to get. thanks guys
SiRcivic27
good choice in the product. The install should be easy with that harness. If you need help with the wiring let me know, I just did so I remember most of it. The E-brake sensor is right next to the drivers seat when you take of the console over the e-brake. For the VSS, I just tapped into the wire right before the ECU connection.
Good Luck!
stealthy
Good Luck!
thanks alot, ill let you know if i run into problems (more than likely!)
