Turbo VS Supercharger
Status
Not open for further replies.
Boots
Yeah I have been planning on going turbo on my H22, but some people have been telling me to go with a jackson racing supercharger, Im going to run 6-9psi on stock internals until i need to rebuild my engine, then I will go up in boost. I wanted to get some info from people. I found a jackson racing supercharger kit that has 900miles and includes everything, but it say its for 97-2001 nonsh prelude. Im wondering if I could make this kit work on my H22. Thanks, oh my egine is out of a 93 prelude.
stealthy
4 Doors For More Whores
turbo turbo turbo
Handlebars
None Taken.
moved for the n00b. on the jrsc note, they are usually ONLY for the specified car, because they stick out quite a bit and have a lot of firewall clearance issues. some people have made modifications to make them fit on other models/swaps, but id do further investigation to see if its possible. or you could just make your life easy and turbo.
Boots
ok thanks, sorry for not posting in forced induction, I will probably just run 7psi ,then i will get my engine built and run more boost. I will probably go with a turbo setup, I just found a pretty good deal on that supercharger and I wanted to see what people thought would be better to go wiht. Thanks
Boots
Ok thanks for the help, I just wanted to get more info before I decided to go with something, I going to go with turbo, Thanks.
Fast_RPM
stealthy said:
turbo turbo turbo
YES TURBO,TURBO,TURBO,TURBO,===========D you'll love it more, and also you should be able to boost higher then 6-8 psi on stock internals
stealthy
not on a h22,big guy
Boots
ok thanks, I will make sure I look before I post, thanks for all the help, Im going to go turbo. Thanks.
Shogun
is cool
yeah, the max for a h22 on stock internals is around 8 psi. I think you can get 10 if the air/fuel mixture is perfect
that VERBAL
AKA Theiven Stealberg
PSI means nothing, power output is what will determine the longevity of a stock engine.
slowhatch
torque?
as for psi is relative to the turbo/supercharger your running. and how is creating a new thread quicker than searching? it takes people forever to respond to threads especially when there is about a million threads out there on the topic.
Mr. Jollypants
Mr. f**king Jollypants
RedLine42 said:
Turbo on a 4cyl. Super on a V8...
PLEASE.. PLEASE.. Do some research.
Both have their goods and bads, one if better then the other for certain events.
Basic run down:
Supercharger - Usually about the same or lower priced then turbos, gives power throughout powerband, uses engine power to create the power.
Turbocharger - Usually about the same but sometimes higher priced then Superchargers, uses engine exhaust gasses to spool the turbo which doesn't take away from engine power, most of the time, spools up during higher RPMs.
Mr. Jollypants
Never really is a good idea, in the beginning, to turbo a stock engine.
Status
