turbo
stdeath1101
f**k it
so i finally decided boost is the way to go.
i have a stock y8 motor in my 95 sedan.
where the hell do i even start? i know i can't just buy a turbo and install it. what do i need for my engine to be able to handle it? i don't wanna f**k it up.
97GreenEX
SiR=Hotness
Compression test. Might as well strengthen the bottom end because D series rods are thin and prone to breaking. Just what I've researched...On the path to boost as well...
TiiM iiS l3eAsT
Scamming Piece Of s**t
ehhh you can run on a stock motor around 220whp b4 the rods will start to bend...just look into greddy kits if you dont know much about turbo's.....also you have to get new fuel injectors to put more fuel in and then have to get a good tune on your ECU....find a dyno around your place and see what they can do for dyno tuning your car.....i would look into www.turbod16.com for research......just do alot of research.....ive researched for over a year and am still learning new things by the day
Steven.
Formally Green 91
where did you hear this?
my brother runs more, on his D17 at that
TiiM iiS l3eAsT
well 220 is around the limit....i didnt say it IS the limit i said its close enough..... go to turbod16.com and ask them they will say the same......ive seen around 240whp but thats pushing it to much for me.....plus im tryin not to blow his s**t up....geez =P
