Boost is better!TougeRunner said:N/A is best ....
duFf_M@N said:in regards to the question. I just asked about the same question to my mechanic, but I asked him on a supercharger. He said safely you could run on 7psi. I think that would aply for a turbo aswell. Anything after that an upgrade in ternall would be necessary or blowing up the engine.
Yeah comptech makes superchargers only but i was assuming everybody knew that, my mistake. I just mentioned the supercharger kti bc it was a type of boost thats all.ShinsenTuner said:Comptech doesn't make a turbo kit for the S2000 does it? I always thought it was supercharger![]()
nice info... wrong car! lol. the s2000 revs much igher than an rsx and has a much different compression ratio i believe.Special_K said:well running High boost isnt the problem, its the EMU and the tune, i kno a guy who ran 18psi on stock internals. everything was fine, hit some good numbers, it was a RSX Type S. he did it cuz he had a good EMU, (KPRO) and a good tuner.
thats wat ur friend needs, instead of asking ppl...cuz we dont kno how much he can run or wat numbers he will get. get a good emu, and a good tune and your good to go
i think you read my post wrong, i didnt even get into comparing the RSX w/ the S2000, i just used it as an example of Good EMU & Good Tune. read a lil clearer next timesohclubkid said:nice info... wrong car! lol. the s2000 revs much igher than an rsx and has a much different compression ratio i believe.
it all in the tunesilver booolet said:i say under 10psi you would be fine. i would still strongly recommend a tune!
