Shiznit said:dude there honestly is no comparison between the gt series turbos and the hybrid t3/t4.
The more advanced compressors and turbines are the main benefit.Shiznit said:ball bearing turbo for the win like i said... the ball bearings make turbo lag almost non existant on the gt series. and the gt28 is a monster size turbo so you would expect it to lag a lot on our puny civics. but yeah, it doesnt lag as bad as a t3/t4 .63 ar and produces more power than the hybrid. but of course you do pay about $700 more for the added performance of ball bearings with the gt series
Get the .64a/r and go with the 2871R not the 28RS.--<EM1>-- said:ok so the .86a/r won;t spool as fast? i can get the .64a/r and the .86a/r for the same price.
which turbo are you refering to? if youre talking about a .86 ar t3/t4 forget it, by the time you fully boost its time to shift. if youre talking about a .86 gt28r then wtf go for it--<EM1>-- said:ok so the .86a/r won;t spool as fast? i can get the .64a/r and the .86a/r for the same price.
http://cheapturbo.stores.yahoo.net/gt2871r.html
http://cheapturbo.stores.yahoo.net/gt2871r1.html
The .86 a/r GT28 is unecessary unless the displacement is there to require it. And with a 1.6-2.2L, it isn't.Shiznit said:which turbo are you refering to? if youre talking about a .86 ar t3/t4 forget it, by the time you fully boost its time to shift. if youre talking about a .86 gt28r then wtf go for it
The two links I clicked on were for the 2871R with either a .64 or .86 a/r.Shiznit said:the links he provided arent gt28's they are gt25's, but i do agree with you
--<EM1>-- said:the links i put up there say gt2871r. then why does it say that the turbine is a gt25?
It says the turbine is a GT25 because it is. And with the GT2871R stick with the .64 a/r.--<EM1>-- said:the links i put up there say gt2871r. then why does it say that the turbine is a gt25?
out of those two. you guys told me to go with the .64a/r. are those turbos not what i should be looking at?
so ill be looking at the second link i posted?Revolver said:It says the turbine is a GT25 because it is. And with the GT2871R stick with the .64 a/r.
