turboing my em1
Kihun_Cha
okay guys im here and im thinkin if i should fuk about All motor
my car runs late 13's wit all mod but the thing is
i have high compression which is ctr 12:1 piston
so say if i get turbo
i can barely run 5psi right?
s**t might not worth it.. nebody done dis wit high compression car?
SeanMc300
professional a*****e
youd want to birng your compression down to atleast 10:1.
evan2
Search owns you
stick with na, with your mods you should getting some better times
you on street tires, whats your suspension set up
its not all about making power, turbo would just make you have less traction if your running what you are
what cams what fuel you got now to go with this compression
header? exhaust
a few small things could be holding oyu back
and no dont boost on your comp
evan2
Search owns you
and CTRs arent 12.1, it just depends on what set up you throw them in....
HiGH_CiTY
Lock It Up!
i thought u said in a previous thread that ur car runs 14.5? anyway, there is a guy up here w/ a 00 ITR-t and he's throwin down 422hp w/ stock internals. not sure what size snail or how many lbs of boost he's running but it has to be around 15 to 18psi to throw down those kind of #'s . this is what i believe is proof that it's all in the tune. so far his best 1/4 mile time has been 12.7 on street tires (high altitude). personally if i had a type r or a higher compression motor i would not turbo it. but i luv turbos
if u are serious about boosting ur motor i would research the tunners in your area and see what kind of cars they have built so far and go from there. without the proper tunning u put ur motor at risk. u should be able to find a lot of info on the net too.
Destroy
get some slicks, and see what you run
