uh..what goes on here?
xxsenceo89x
aka superman
idk what kind of flange it is or where i would find it. help..?
its where the air filter would go. it looks like a lemon with 2 holes in it
codyllee
what turbo is this? t25 or t28? either way you need the elbow that attaches to the inlet (your lemon shaped hole) these are usually off a sr20det
Here is a pic of a garrett t25 off a nissan sr20det
this is an elbow that you CAN use, but i would recommend that you just make your own, it should not be difficult at all :D
xxsenceo89x
aka superman
its a garrett T3 60/63. i think i can use an elbow off any t series but im not sure if theyre the same size
codyllee
ok, in that case just fab one up.
codyllee
It depends on what position your compressor housing is at...
Any muffler shop should be able to help you out for really cheap; im sure they have plenty of scrap material to give you for next to nothing :what:
xxsenceo89x
aka superman
its the flange that im worried about. i can get a pipe welded on. should i just make one with a plasma cutter?
codyllee
make a template with a piece of cardboard and take it to a machine shop? Take the turbo with you too and kind of explain what you are doing/looking for
bizoneoeh
Ex-Gang Member
some flex pipe and some jb weld will work fine ;)
:lol: you can probably have one fabbed up locally for pretty cheap
95_civic_lx
that piece that u posted if from a DSM turbo compressor outlet....i have one...the hole is about 1.5 inches at the flange side and 2 in at the exit side....so that wont work since ur compressor inlet should be bigger...u can buy the flange and go to any local exhaust shop to weld a small piece of pipe to it and use couplers or u can get a piece of pipe and weld that b***h on....or just JB welded on...just make sure it doesnt drip to the inside.
xxsenceo89x
aka superman
compressor outlet? the flange that i need sucks air in. wouldnt it be compressor inlet?
