so i recently installed a gsr in my hatch. on start up and normal driving the car runs great. i took it to my tuner and got a baseline tune and it put out 153whp...not bad for a bolt on gsr right? the only thing is that in vtec it blows out a lot of blue smoke. i ran a compression test on a cold motor and it was 175 across the board and i did the test again but this time i added a cap of oil to each cylinder and the numbers didnt go up more than 5 psi in each cylinder. im pretty sure its the valve seals because the motor does make the power it should but i would like a 2nd opinion.
when i got home from getting my car tuned i checked my oil and it was a little over filled(half a quart), would this cause a lot of blue smoke by chance?
will lucas fix my issues at all?
thanks
thanks
