Dnt feel bad man, at some point everybody had to find out that same answer. Im glad that nobody flamed you for the newbie question. Im new to this site if you didnt notice, check my post count.Slick_99 said:Thanks guys sorry for the n00b question but I had no clue how it works. It puzzled me that is was mounted to the header but your explanation completely answer what I was asking. Thanks.
Are you on crack? Since when can you use a stock mani (without MAJOR fabrication) and mount a turbo on it???????????? I have NEVER seen that anywhere.RKSskier said:turbo's need the air from your exhaust. They get some of the air that goes through the exhaust, and it is used to spin the turbo and build boost. And I think what you may be asking is why do civics, unlike many other cars use the actual stock exhaust manifolds for the turbos instead of the tubular ram horn style manifolds. If so, that is just becuase the older model exhaust manifolds on the std standard and hf civics, from 88-91 i believe, can be adapated to fit and mount turbos. I hope this helped some
ryan
on d-series civics they use the stock manifold where the catalytic converter blots to it. U take the cat off and use an adapter plate the bolts to the manifold and u also make hols so u can bolt a turbo to it. Ive seen a couple cars like that. budget turbo kits man.MySiIzFaster said:Are you on crack? Since when can you use a stock mani (without MAJOR fabrication) and mount a turbo on it???????????? I have NEVER seen that anywhere.
99.9999999999999999999% of time its after market manis. 8)
thats some scary s**t..... not very efficient..... ghetto if you will.btec said:on d-series civics they use the stock manifold where the catalytic converter blots to it. U take the cat off and use an adapter plate the bolts to the manifold and u also make hols so u can bolt a turbo to it. Ive seen a couple cars like that. budget turbo kits man.
i agree its ghetto but its pretty much the same as a log style manifold.MySiIzFaster said:thats some scary s**t..... not very efficient..... ghetto if you will.![]()
who are you talking to? You should probably quote the person you are talking to.boostedb16 said:sorry, this has nothing to do with your question, but if thats your car on your sig, what size wheels do have and how low is your car, im putting 18s on mine and what to know how much to lower it, thanks , and again nothing to do with turbo.
