Viper 5000 remote start?
dj_audio
I was wondering if anyone new of a way to add remote start to my current alarm. I have a viper 5000, pager alarm that i know comes with remote start, but the shop i went to said they couldnt install the remote start on a 5 speed manual car. I know theres a way to install it, and im wondering how to do it and what it would take to install. Any help? anyone in a similar situation? Thanks
EG_CaSe
ScAre CrOw
yea i just got the alarm lastnight and tryna figg out how i can do it myself also..
i find anything ill let u know
EDIT: i found this lastnight, it dont explain much but maybe it will help u some
http://www.drdetailshop.com/STARTINSTALL.html
dj_audio
thanks yeah, im wondering if theres any other pieces we may or may not need to install.
cujo613
on five speeds you have to use a neutral safety switch. They run about $100-$140 installed depending on which shop that you go to. Remote starts are definately a project that you dont want to tackle by yourself. Not fun. And guarantee it worth paying a shop to do it rather that paying a shop to rip out the install and do it over
dj_audio
Are you speaking in general for 5 speed remote starts or specifically for the viper alarms? What does the neutral safety switch actually do? Prevent you from remote starting in gear, and does it allow you to start your car without engaging the clutch? my car needs the clutch engaged to start, so i was wondering if it would also allow remote start to work without the clutch being engaged.
uwishucould158
there is no differencee than installin it on an auto car then 5 speed they dont do it cause its illegal u dont need the switch jus dis engage the clutch so that u dont have to press it in to start the car it be best if u didnt do it in rural areas u gota come to the city like in the bronx or somthing where they need money and tell to do it if not then dont do it and they will be like ok
EG_CaSe
ScAre CrOw
^^WERD... i know over here anyone would do it.. BTW u dont need the saftey switch everyone is talking about.. my boy hooks up alarms and i asked him about it he said its just some wires.. to bad hes gunna charge me to do it
dj_audio
do you think you could find out which wires? I'd kinda wanna have the safety switch anyway, but yeah, thats what i really wanted to find out, how to hook it up.
EG_CaSe
ScAre CrOw
ill see when he runs mine.. u know ill be watchin
dj_audio
haha yeah, take pictures or film it or something so we could have a how-to for club civic. LOL
rolakers
Milkman Insane
When I got my alarm, they told me that it was illegal, but I heard that other shops will do it. I have a python tho, couldn't find Viper around here, except at Best Buy and it was ridiculously expensive
EG_CaSe
ScAre CrOw
im almost 100% sure its the same thing as the viper 5000.. just some little things it might not have
cujo613
The neutral safety switch allows you to autostart the car a guarantee its not in gear. It is 100% illegal to put one in without the neutral safety switch, but legal with. I would steer clear from a shop or a friend that would put in an autostart not using the nss
EG_CaSe
ScAre CrOw
yea it isnt that safe without it.. the other day i had my boys car and tryed it out i forgot i left it in 2nd and the car took off on me.. it went about 10feet be4 i could open the door and hit the brakes.. theres a way to shut it off from the remote but i didnt know how..
i also broke his starter doing that
rolakers
Milkman Insane
Since I didn't get the remote start, I got the window module. It's a lot of fun, the button that would start my car, rolls my windows down, and the lock button rolls them back up. It's sweet, people always look at it and go Oooooo and Aaaaaa hahaha
EG_CaSe
ScAre CrOw
that is hott i wanted to do it but i have a problem with one of my windows so i said forget it.. i gotta lube up my window or something..
dj_audio
yeah its pritty sick. for the viper alarms you have multiple aux switches so you could have both. I think if you hit two buttons at the same time it can run another aux input, ie window modules, or even you can program it to open your garage door if you like. The window module is pritty cool, i'd install that too if i had power windows. My dads 03 accord comes factory with it, and its awesome.
cujo613
12volts
white (40A)
ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Keysense blue/white to blue/red - ignition harness
Power Lock green/white - driver kick, blue plug
Power Unlock green/orange - driver kick, blue plug
Lock Motor white/red 5wi driver kick, door harness
Unlock Motor blue/red to yellow/red 5wi pwr door lock ctrl unit in driv door
Parking Lights+ red/black + driver kick, fuse box
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) green/red + steering column
Turn Signal(R) green/yellow + steering column
Reverse Light green/black + driver kick, harness to rear
Door Trigger lt. green/red - factory alarm plug
Dome Supervision lt. green/black - driv A pillar or factory alarm plug
Trunk/Hatch Pin blue/black - driver kick, harness to rear
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac test tachometer connector
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake red/green - parking brake switch
Horn Trigger blue to gray - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
EG_CaSe
ScAre CrOw
dj_audio said:
did anyone figure out how to wire the remote start yet?
i am no longer doing remote start.. when i got the alarm done they said they took out my kill switch but they didnt. so i rather keep the kill then add remote start.. this kill pretty much kills everything, windows. locks. dizzy, starter, fuel etc..
