Depends on what wire in the TPS connector you're talking about.whats the voltage i should be getting for my TPS?
No. The TPS output voltage must be calibrated after installing a new TPS. Afterwards, reset the ECU.and also is a TPS installation just as easy as removing it and just replacing another back onto the TB?
And then voltage calibrate it and reset ECUSo when I remove it I would need to disconnect my battery
install the new 1 and
reconnect my battery?
Got oneTo start, you need a multimeter.
This you have a small gap where it can be placed within. You want to be as close as possible to that number. It take a little bit of patience to do so. You may want a seperate set of hands.before you remove the old TPS unplug it and put the multimeter on the pins inside of it and write down that number. when you install the new one you move it around until its back at the number you wrote down.
99 civic,lx, d16y7Year, trim, engine?
But what if the voltage isn't right? Or can that even happen? I'm new at this stuff so im a little paranoid lolbefore you remove the old TPS unplug it and put the multimeter on the pins inside of it and write down that number. when you install the new one you move it around until its back at the number you wrote down.
Measure voltage between the middle Red/Black wire and the Green/Black wire in the plugged in TPS connector with the key in ON(II). This is done by using needles to back probe the TPS connector.99 civic,lx, d16y7
Loosen the bolts securing the TPS and turn it until the voltage reads 0.5V with the throttle plate fully closed. Then tighten the bolts. When the throttle plate is wide open, the voltage should read about 4.5VBut what if the voltage isn't right? Or can that even happen? I'm new at this stuff so im a little paranoid lol
Bolts? It looks riveted on the tb so I'm guessing I'm going to have to cut them off and replace it with bolts right? And when I look for the voltage with the wot and ct should my car be on?Loosen the bolts securing the TPS and turn it until the voltage reads 0.5V with the throttle plate fully closed. Then tighten the bolts. When the throttle plate is wide open, the voltage should read about 4.5V
Remove the TB, Dremel tool a straight groove across the top of each "rivet" bolt, and then use a flat head screwdriver to remove the bolts. The new TPS generally comes with two new bolts with hex heads. Install new TPS as well as TB with a new TB gasket.Bolts? It looks riveted on the tb so I'm guessing I'm going to have to cut them off and replace it with bolts right? And when I look for the voltage with the wot and ct should my car be on?
