Lucid77
Ok, I've replace a few things in my 99 civic ex (distributor, large vtec gasket, etc) recently. I know I have a decent oil leak problem I've been keeping an eye on. (1 1/2 quarts every 1500 miles). I took it into a shop and they said vtec gasket (smaller top) and internal distributor leaking. Once we fix that then we can clean it up and see if the rear main seal is leaking. Well the oil is coming from top down and splashing all around on top of the transmission. Gasket between distributor is fine. But oil definitely coming somewhere around there. 3 days ago it started losing TONS of oil. All over driveway. Had to refill 3 quarts or so. I degreaser the engine and replaced the smaller vtec gasket and now it seems the leak has completely stopped!!??
Is it common for the vtec to dump so much oil?? The old gasket was really flat, but not broken.
This seems too good to be true. Any thoughts?
