VTEC HELP! (pr3)
xx90vtecxx
sLeEpErS.cOm
ok, im running my vtec wires and i need help on identifying the other wire thats on the pressure switch. i know that the wires are a possitive and a ground but heres what i got......
vtec solenoid = A8
pressure switch = B5
i need to know what the 3rd wire is.
heres the site i used.
http://tech2.hybridgarage.com/ecu.php?ecutype=pr3_a
93turbo16
vtec solenoid = A8
I am pretty sure the other wire on the pressure switch is a ground. You can ground it to the frame.
EG-Owns you
Twin Tech Owns Your s**t!
ya ground the 3rd wire to the frame but make it look clean get some plastic shroudling and cover the wires and s**t and run the ground to the back of the firewall or you can splice open the stock wireing harness and run the wires in that and get new shrouding that way to witch im gonna do here so once winter hits woot
xx90vtecxx
sLeEpErS.cOm
well which one is ground now? the bottom or the top pin coming out of the pressure switch?
EG-Owns you
on my its a black wire and its ont he pressure switch
xx90vtecxx
sLeEpErS.cOm
ya but i dont have a plug right now. so which pin is it on the switch itself??
EG-Owns you
um no clue for your year car sorry look it up on ecu pinouts
