vtec light
rioc892002
hi was up guyz well i was up on the site and i saw something about the vetc light well i made me one and i hooked it up to my vtec silenoid and i soldered the wire to gather and then did my grounds and everything but when i let the car warm and everything the i took it for a drive and the light came on for i little sec like something was wrong then i check the led it was blown the i got another led then hook it up the light did not come on at all then i check it it was blown again. then i got a new led and hook it up it did not work again i check the led and it was working fine. I DON'T KNOW What is going on is vtec working or what. i don't want to hook it up to my ecu be cause too many wire i also have a 97 honda civic ex
cgpEJ6
noob
It's something to do with your wiring, not your VTEC
EG_CaSe
ScAre CrOw
make sure it got enuff ground.. and make sure all ur connections are good..
xdr3amx
http://www.hazone.com/hvlight.htm
yes you can buy a led with a resistor they sell them at radio shack also otherwise this is what you need Package of 330 OHM resistors Part# 271-1113
if not you will burn the led everytime
EG_CaSe
ScAre CrOw
99hatchie said:
cool, maybe I'll do this when I get a vtec engine.
its worth doing.. alot of people that know i have it say ohh that Gay but its like a Safety feature..
xdr3amx
it's only worth doing caused it cost about 3 bucks, but really it doesn't do much. some say they will do it for the fact a sohc vtec you can barley tell your in vtec. but i mean you do it for yourself more than anything else. could be any number of excuse right
