Want To Change Led Dash Lights
feras90
i want to change my dash lights in my car but i dont know wat website to go to to buy the exact led dash bulbs to fit. Is there a specific name. Any advice or any website will be much appreciated
knightxrider1
superbrightleds.com
KJS888
some reason my lights for my interior are getting dimmer?, has anyone esle had this problem? and what can i do to solve it?
97GreenEX
SiR=Hotness
Either of those sites will work. I used autolumination.com.
It looks all the same shade of blue in person. No really obvious hot or cold spots.
OC_Civic's How to.And the dimming may be due to bad grounds, low battery. When does it happen? When you're playing music?
B16a2_ek
what size resistors did you use for the amber.? my climate contrl keeps going out.. could it also be that I used tooo thin of a wire? and my 3 buttons below that are way too dim u can barely see it...... I didn't solder it to the circuit board I jus pulled oouut the original bulbbs and rigged the wires into that llastic socket thing..
Z-Tec
any guides out there on how to change the light buld in your yourself?
JoshBrower
Which bulbs did you have to replace? I took the guage cluster out a while ago and I was confused about what bulbs lit up what parts of the guage.
gearbox
some people use the premade ones, idk if they have any for older civics, but ledautomotive.com sells kits that replace the bulbs.
B16a2_ek
hey gear box do u by any chance remember what resistors you used? i think i used 45ohm on mine but they blow out every now and then
Ian123
should i buy the ones that say theyre 3 times brighter than standard or will the cheaper 50% brighter ones do the job? also why cant i find any #194 size bulbs on autolumination all they got is #74s
