Washer trick.........who has done it?
DXorcist77
Bootyoligist
Who has done this trick and what are the measurements of these washers? How many will i need? Help me out.:D
DirtyD
WTF are you talking bout
Beelzebubba
SubGenius Member
Did I miss a link or something??? What trick????
b16asi226
The East Coast Kid
????? im confused.....we took the sprayers on my friends probe and turned it to spray people. itwas some funny s**t. that what you mean Mr. Montana...you cocharoach???
Beelzebubba
SubGenius Member
Meester Montana joo cockaroash.......LMAO!!!!!
DirtyD
thats friggin hillarious,I'm gonna do that now
2kstreetcivic
Runnin to Redline
I know what you are talking about.....I have heard that you want to ger 1/2" washers and that should change the camber by about 1/2 a degree for each washer....I will check on that for you and get back to you though
2kstreetcivic
Runnin to Redline
ohh, and for clarification, the washer trick is a trick to fix rear camber without buying a camber kit..if you only need like 1 degree or so, you can use the washer trick...what you do is you buy a longer bolt and put washers on it and it will fix the camber..its works.
b16asi226
The East Coast Kid
im still confused??? what are you doin? putting your washer sprayers in the plastic gaurd by the winshield?
2kstreetcivic
Runnin to Redline
No..its for rear camber...you put circle washer, like bolt washers you use when you build something out of wood and you screw it down something....And you buy a longer bolt, and then put a certain amount of washers on that bolt to fix the camber....
b16asi226
The East Coast Kid
ooohhhh....ok, gotcha. i know what you mean. check out the suspension forum, i saw something like that the other day while i was perusing that one.
2kstreetcivic
Runnin to Redline
yep, this is a well know trick
DXorcist77
Bootyoligist
Manolo(2kstreetcivic) muchas gracias for splanin to thees cocaroaches abou da camber washer trik meng. Look up that measurement for me amigo. 8)
Rand0m
Adamantium Member
you dont need any measurements...just go buy some washers....i did that for my si, and it worked fine....you dont need longer bolts....just go buy like 4 or 6 washers...2 or 3 for each side
oh yeah, that accent worked for Pacino...its not workin for you though
DXorcist77
Bootyoligist
Thanx for the info. About the accent.....if u heard me u would like it.......maybe.=)
Rand0m
Adamantium Member
haha, its funny because as soon as i sent that, i sat here and tried my luck at the accent...i couldnt pull it off
DXorcist77
Bootyoligist
LOL. Keep practicing. U just gotta make the face with it too.
