Water leak in passenger side under dash - common?
Anarchi
Hi all,
Under the dash on the passenger side (left side in Australia), when it rains there is a water leak coming out from where the ECU code plug area is, obviously there is a seal or something that has come loose. Any idea where the leak is occuring? The lower windscreen plastic cover (under the wiper blades) is lifting a few millimeters from the glass, causing leaves to jam in there, would this be the cause?
Is this known to be a common problem with the 92-95 Civics? I guess if it happens to a left hand drive car it would happen on the right passenger side.
Jas0n
What's up dogz!!!
yes it is...
95civichatchcx
ive never noticed it in mine, maybe im lucky for once..but i doubt it i better go look....
RevHard92Si
Have you ever replace your windshield? I had my windshield replace about 2 years ago. That window company did a shitty job. Now when it rains or if I'm washing my car there's always water dripping down by the ecu and the driver side kick panel. I did some checking and water is diffently drippin throw the windshield seal.
Anarchi
No I have not had the Windshield replaced, somehow it just came loose - possibly to hot weather? I'll look into replacing the plastic cover or applying silicon into the gap.
