Weak Deck?????????
Mr.Luder
SSM EP3
So this is wut I have!!! LOOK BELOW
ALPINE CDE-9843
PIONEER GM-X372
10" AudioBahn 300Watts RMS 600Watts Peak
The Amp Is bridgable {+]Left [-]Right!!
So my problem is when I connect the AMP and SUB wit my sisters deck which is 45x5 it bumps how a sub should bump...NICE CLEAN LOUD!! Well Perfect Loud, Not to Loud!! Than when I got the new Alpine deck connected everything and its hella weak...Bumps just as hard as the regular speakers so I thought the SUB wasn't working but when i listen closely it is!!!! I thought I connected it wrong and did a double check and everything was right!! When I mean weak I mean weak, thats how it sounded wit the ALPINE in my car!! WHATS WRONG? The Alpine Has sub control but the subcontrol cant even control!! when I up the regular bass the freakin sub goes up on bass and so does the regular speakers...and all are at the same sound level no matter how high i turn it!! HELppppppp??
DirtyD
its the settings on the deck
try and do it yourself but I couldn't on my buddy's deck (the exact one you have), a shop will do it for very very cheap if not free
Mr.Luder
SSM EP3
settings? what settings? And wat do i ask the shop?
anekin007
Unregistered User
ask the shop? open up ur manual and start reading.. u can learn a lot.. lol .. also.. are the rca wires the same? are the power and ground wires the same as in ur sisters car?
$lick Rick
TEOTWAWKI
it sounds like your wiring is messed up or the settings on the deck are wrong.
you should have 3 sets of rca outputs on the deck, make sure that your rca's are plugged into the correct outputs
Mr.Luder
SSM EP3
i mean i've done this tons of times to my friends car my pass cars my sister's car! maybe i should read the manual? i think its just a settings on the deck i mite of missed but im almost sure i messed wit everything on that deck already...the back only has two rca plugs a red and white that says sub output on the side!!
yea im using the same wires ...everything
Mr.Luder
SSM EP3
Holy s**t I Just Learned Hella From My Manual!! Let Me See If I Can Figure It Out!!
Mr.Luder
SSM EP3
so the manual tells me to go to initial setting and turn the power on/off and if i have a external amp turn it off....but when i turn it off all the speakers connected to the deck stops working....i dont have the sub plugged in yet but i was just tryin to figure it out...if i have the sub plugged in will it still do that?
booze_b
At work CC user
:what: Can you clear up ur last post a little?? What I got from it is when you turn the deck off and disconnect the amp your speakers stop working.
k, assuming that you're highs are running from deck power and the amp is running the sub only, you say that if you disconnect the amp the deck speakers quit working? I'd suggest that you have a ground problem with the deck.....and possibly the amp as well. I'm still lost though.
DirtyD
are the subs moving but very very softly?
if so it is the settings, you should take it to a shop and try and get them to fix the problem
anekin007
Unregistered User
check the db setting on ur deck for the sub.. there should also be a seperate volume adjuster for the sub.. the external on/off feature is only use if u have all ur speakers running from the rca.
Mr.Luder
SSM EP3
no the deck is on...the settings have a control where u can turn off the built in amp...but when i turn the built in amp off all the speakers go out...the built in amp inside the deck!
Mr.Luder
SSM EP3
as i said i my first post i used those controls and it didnt help...maybe if i hook up everything and try it again
anekin007
Unregistered User
check the manual to see if there is a setting to switch the rca rear to sub.. since u only have 4 rca .. one pair is front speakers and other one pair is switchable rear speaker/subs. ur sub might be running as a rear speaker considering what u said in the first post.
charles_00Civic
CC'S Longest Running Noob
Try toying around with the deck's settings. Man, everyone and their dog has that deck. Its ncie though, but common
Mr.Luder
SSM EP3
i only have 2 rca sub outputs....red and white...and it says sub out put on the side
