Hello.
I have some problems with mi ecu. A friend of mine chip my ecu, the ecu is a p29, the setup is this:
D16a9 (dohc d-series) turbo 10psi, 240cc inyectors, walbro 255lph, fuel rail presure 45psi, stock map sensor, everything else is stock.
My friend sent me with the ecu chipped with three diferent maps, one for 440cc inyectors, and the other maps he did a conversion to my 240cc inyectors, he use crome software.
The problem is this, when i turn the car on with any of these map the car smokes black too much, wont past from 4000k, and do many backfires at 4000k very loud.
The strange thing is that i removed the J1 brigde to use the stock map again to test and the car run the same.
What could be happen here?
I Alredy put new spark plugs, another tps, another sensor map, and the car still runing the same with the stock map.
Thanks.
Thanks.
