What are safe jack points?
chimchim
iVTEC, do you?
I'm not fortunate enough to have access to a lift. So I use a pnumatic jack and stands. However, in order to use these, you need TWO jack point near each other. So... please let me know if there are good jack points that won't screw up my chassis:
front:
- the two side jack point under the side mouldings that the manual tells you to put the emergency jack at when you need to change a tire
- the lower part of the LCA where the shock connects to the LCA
- the upper joint of the LCA where it connects to the subchassis
- the square subchassis bar itself in between the LCA joints
- the two tow loops under the front bumper
back:
- the center tow loop under the bumper
Please confirm?
