What ECU to use?
chameleon30038
Inquisitive
Need to figure out what ecu to run my set up on. Looking at something like 12:5 compression. Also what program to tune with i know i can't afford hondata at the moment. I'm guessing i would need a chipped ecu, conversion harness and about 2hrs dyno time/tune. Also do you think i need to upgrade to a walbro 255 lph? Also how about a FPR and Rail? All constructive input would be greatly appreciated since i don't wanna blow this and all i have is a stock pr3 ecu.
B18C stock bore
CTR Pistons
B16 Head
Cams
Springs
Retainers
93turbo16
B18C stock bore
CTR Pistons
B16 Head
Cams
Springs
Retainers
You will want a chipped P28 and run it with crome. You will also need a OBD2B to OBD1 conversion harness to convert to OBD1. You should be ok with stock rail and stock pump. But I would upgrade your injectors to 310cc or so just to have room to play.
If you need help deciding on ecus and programs, just shoot me a message.
Phantom Civic
Never Satisfied
took the words right outa my mouth.
chameleon30038
Inquisitive
Thanks for the input guys!
