well im plannin to turbo soon by summer and I wanted 2 know what electronics I will need to turbo so I can know how much I need to spend. I already know I need a turbo timer but what else is there I need too..
You dont NEED a head gasket or head studs though. Get a hondata S200 with boost some 550 injectors high pressure fuel pump then get it dyno tuned there you go.Tainted Ramen said:the right way....5,000 (injectors, head gasket, head studs, turbo, fuel managment, gauges, intercooler, bov, you know, the works)
and dont bother getting an apex'i vafc, or safc....there just expensive indiglo clocks
Yeah but you knew what i meant with my setup i will need high pressure so im getting a lil confused. Sorry. 8)SeanMc300 said:^^ correction not high pressure, high flow. since with the hondata you wouldnt be using the fmu/link setup, therefore you wouldnt need a high pressure.
also, ive been told by two tuners that they prefer if customers get the s200..its more friendly and easier to tune/use. they see tuning costs cut by 40% when using the s200. the right way....depends on what power you are looking for (remember dont set psi goals, set power goals).
total price of electronics would be somewhere around...
Turbo Timer: 90
Guages: 175
Hondata: 800
Total: 1065
believe me, spend the money.
no, it doesnt replace the factory ecu. The s100 is a little chip that goes into the ecu. But the s200 does have that little blue box. But it doesnt replace anything.importlegions said:does hondata replace the factory ecu?
dude, the hondata doesnt have a boost controller in it..Tainted Ramen said:some gauges will help you in monitoring things; Oil pressure, Air/Fuel mixture, Boost...you will also need some sort of management system like Hondata, or AEM's comp., or GReddy. If you go with hondata it has a boost controller in it already, not sure about aem though.
