what engine harness and ecu do i need for a 1999 civic hatch with an sir1 b16a
civic_hatch99
First off i have a 1999 civic hatchback with a b16a sir1 engine. I don't know why they swapped that old of an engine in there but i cant complain the car was free. Anyways, im tring to get it running as good as possible. I want to know what wiring harness and ecu i need for me to get it running right. So far ive read on one thread that i need a engine harness off of a 92-95 honda civic SOHC VTEC is this correct? Also it said to use the p28 ecu. Would this be the right set up to use to get it running correct? Please help me out.
Intertwined
It's onski brah
im not sure on the harness, but if you get a P28 ecu you will have to have it chipped and tuned......a P30 ecu will run a B16 just fine. regardless you will have to run a jumper harness at the ecu as 6th gen civics are OBD2.........heres the wiki info off the B16A SIR 1 which lists its original ECU
B16A found in: 1989-1993 Honda Integra XSi
1989-1991 Honda CR-X SiR
1989-1991 Honda Civic SiR (EF9) Displacement: 1,595 cc (97.3 cu in) 1.6-litre
Compression: 10.2:1
Bore: 81.0 mm (3.2 in)
Stroke: 77.4 mm (3.0 in)
Rod Length: 134 mm (5.3 in)
Rod/stroke ratio: 1.745
Power: 160 PS (118 kW; 158 hp) @ 7,600 rpm & 15.5 kg·m (152 N·m; 112 lb·ft) @ 4000 rpm
Redline: 8200rpm
Transmission: S1/J1/YS1 (4.4 final drive, cable clutch, optional LSD for YS1), Y1 (4.266 final drive, cable clutch, optional LSD)
ECU code: P-fk1 (DA6/DA8/EF8), PW0 (EF8/EF9/DA6)
OBD0
CHILD
All Day, All JDM
I just so happen to have a jdm p30 for sale...just in case you need one
