tat2edbit
hi i got a 95 civic ex from my mother that has the d16z6 i drove it to work and as i pulled in the parking lot the belts shredded so after work i put on new belts not really paying attention to the harmonic balancer anyways started driving and the belts flew off so i got it home climbed under it and the harmonic balancer was loose so i took it off only to find that who ever worked on it before cross threaded the bolt letting it back out and wobble enough to cut some small grooves in the block and twist the keyway and broke the groove in the end of the crankshaft so i was wondering if i should rebuild or swap and if i swap what engines plug and play with my ecu and tranny thanks in advanced
