What to do next
shmeg
I have a 6th gen silver ex coupe. Performance wise, all I have done is put an racing series exhaust on her. I've been looking around and can't decide what to do next. I want more loud and eventually to lower and turbo her, but that'll be way down the road. I'm pretty sure I want to get a short ram intake soon, but not sure what brand. Any suggestions?
Failsafe88
gt CasaNova
EBay brand it's pretty much a waste of money beside looks. I say save the money for other parts
CO671
Do you know that Intake/Headers/Exhaust are just that/ NOISE on a d16y7/d16y8.
You're not doing any performance mods, you're doing noise mods.
Stop trying to make it a race car because performance gets you nothing unless it's properly modified internally, tuned/obd1 converted, turbocharged or supercharged.
I said this in another thread:
Why do you need a loan for car parts?
What do you want out of this car, whats your mechanical experience like.
Idk what you use to purchase stuff, but here's a few items I'd recommend checking out for the first $100 to spend:
LED Dome Light Panel: http://www.amazon.com/White-Interior-Light-Panel-Adapter/dp/B009E1BW08/ref=sr_1_3?ie=UTF8&qid=1380430844&sr=8-3&keywords=48smd+led
Smaller Dome light & License plate light: http://www.amazon.com/Jtech-T10-5-SMD-White-Lights/dp/B00877SL2M/ref=sr_1_4?ie=UTF8&qid=1380430864&sr=8-4&keywords=168+LED
Map Light: http://www.amazon.com/Cutequeen-12-SMD-Festoon-DE3175-DE3021/dp/B00AO4QP3S/ref=sr_1_8?ie=UTF8&qid=1380430894&sr=8-8&keywords=DE3175+LED
Wide Angle rear view mirror (Clears sunvisors): http://www.amazon.com/Broadway-Type-Mirror-240mm-Convex/dp/B003VL62AM/ref=sr_1_5?ie=UTF8&qid=1380430995&sr=8-5&keywords=240mm+convex
Integra dual bend shifter (quicker throws into different gears slightly): http://www.d-series.org/forums/diy-forum/9772-diy-integra-gsr-shifter-install-into-civic.html
Choose which one you like and can get secondhand, keep an eye out locally or check a junk yard
Front seat swap (bolt in) stock Civic seats SUCK
~$??? - Seat Swap
More Info
96-00 CIVIC:
-Front-
•92-95 Civic w/EK rails
•94-01 Integra w/EK rails
•97-01 CR-V w/EK rails
•92-97 Del Sol w/EK rails
•97-01 Prelude w/EK rails
•97-02 Accord Coupe w/EK rails
•01-03 CL w/EK rails*Requires 12v for heat feature
-Rear-(Hatch)
•92-95 Civic *Hatchback only
•94-01 Integra *Hatchback only
•02-06 RSX
-Rear-(Coupe)
•01-05 Civic Si*EP3 only
-Rear-(Sedan)
•92-95 Civic Sedan
•94-01 Integra Sedan
Take pictures, this is the best thing.
1) Repair existing problems, FIRST
2) Tune ups, because you just started owning it, reset all the maintenance to your intervals so you know exactly when to change it all.
3) 17 Inch rims are usually too big for a 96-00 Civic, but can be pulled off sometimes; otherwise, it's ugly.
4) How do you know it handles well? What's your driving experience?
5) To tell the difference between cut springs and coils, look at it... Take a picture if you cant tell the difference. So far, I wouldn't be surprised if it's a cut spring or Ebay coil sleeve on stock shocks.
6) Please do your research, or make your own build thread that you can sneak in advice relative to photos. Everybody makes a thread like this and it's annoying, there's enough info on the internet on how you can "How to build my Civic like everybody else"
7) If you want more "UNF!!" without motor swapping, just turbocharge and tune it for 200HP which'll run you around ~$2500, if you don't have the money, dont consider it. If you want to learn more, search it up.
8) If you just want to do bolt ons and you're going to expect power, its a waste of time. You can spend $1000's on headers, exhaust, intake, cam, external coil (MSD), etc;. They're all just overkill. Without a proper tune & OBD1 conversion at this point, you can't get any power, and even with a proper tune, it's just a D-series Civic. An ECONOMICAL engine which it's potential has already been tapped to the best by Honda without turbocharging.
9) Look at your car, figure out what needs to be done before you do any work on it. You'll just be driving a hunk of junk if you accessorize it before you take care of it.
10) Good luck.
Read the thread in my signature or click here
http://www.clubcivic.com/board/showthread.php?t=219682
