What tranny and IM for D16Z6 turbo?
cvnig89
got 2 things i need to figure out. Since my hatch was stolen along with the ls motor i swapped in, i decided to go turbo d. im using a d16z6 and its going to be built(low comp. pistons, rods, etc etc). My 1st question is if i should just use the ex, si tranny or should i use an lx, dx just for a longer gear ratio. My other question is since im going to be using a 14b turbo, ive been reading on the hf manifold and using an adaptor plate, but i havent seen any other manifolds i can use to mount on the d16, so basically what other manifolds can i use for the 14b to mount on the d16z6.
xxsenceo89x
aka superman
A 14b and low compression dont work well. The turbos too small. Use the EX transmission.
cvnig89
well i jus got the d16z6 from my friend who just built the bottom end. I eventually do plan on upgarding the turbo though. but thanks for the input
spoon egg
Teeth Doctor
You should just drop the HF manifold and get a cast iron log manifold. It's only like 100 bucks
cvnig89
well what i was worrying about the hf manifold is how much power can it handle? because im aiming for 200,250whp .
Autoworks
Use the ex/si tranny.
You can also opt for a stainless log manifold w/ a 14B flange...or go with a T3 based turbo (Tr Super 60 .63 a/r) and have a wide variety of manifold selection.
got traction
i rock the sohc
^^ this. And congrats on your new dyno session :D
